I had a problem with this boiler about a year ago and got help from this board so I thought I would try you again.
The new fault has got worse over the last month.
It started with no hot water. This was an intermittant problem which got steadily worse. We managed to work round it as my wife found out that if the central heating was on then the water was fine.
This week things have got worse. The central heating is now intermittant and will not always fire up and therefore no hot water.
At all times when turning on the hot tap a relay sound could be heard from the boiler as though the electronics was ok. The pilot is lit at all times.
Any help is appreciated
BM
BM
