Switch height above floor
30 Apr 2010
Leicestershire
I'm in the process of refitting my bathroom and I need to put in the back box in for the towel radiator heating element, how high does this need to be above the floor? I'm having the electrician put in a programmable timer (Suitably IP rated of course), which I guess means it may need to be 450mm high?
Thanks for any advice :)
Is everything you are installing suitably rated for its environment?
Yep, everything is IP rated for the relevant zones, electrician should be hooking it all up in a couple of weeks
