I am installing an "instantaneous" undersink water heater in a utility room, and will run a separate cable from the consumer unit. I know I need to have a double pole switch to turn it off, and that the switch must be within 2 meters of the heater.
But there are natural stone tiles, large ones, above the work surface that I do not want to disturb. Can I place the switch in the cupboard under the sink? As a 2nd option, could I place the switch on the front of the cupboard?
Lastly, the consumer unit is RCD protected. Do I need additional 30ma RCD protection for this circuit?
Thank you,
Thank you,
