I'm replacing all of the switches in my living room. Can anyone help with a couple of problems:-
1. If the terminals on the new socket are marked COM, 1 Way and 2 Way, do you wire the live to the com terminal, and the neutral to the 1 way terminal?
2. I have a switch that has two switches on it as it used to feed a spotlight in the ceiling. As the spotlight has been removed I want to replace the switch with a single switch. It is wired as follows:
Live to A2 with a connection from this terminal to B
Blue wire to A
Yellow wire to B2.
How would I connect it to a single dimmer switch.
3. Can any light be connected to a dimmer switch.
I have a double switch which I want to connect to a dimmer switch which is marked
Live, Switch and earth and there are 2 seperate sets of terminals so marked.
As I had 2 sets of wires on the original switch I thought that it would be a simple case of wiring each set to the live and switch terminals but when I did each set of lights would not turn off.
Can anyone help a dimbo please.
Blue wire to A
Yellow wire to B2.
