Hi guys,
I have a switched fused connection unit in the living room - the load was intended to be connected to an electric fire, although I have instead connected the load to a 6-way trailing socket. I also relocated the fcu - no major changes, I just unwired it, moved the box a few inches, and reconnected. It all works fine, but the odd thing is that sometimes when I switch the fcu on I can hear a quiet, high pitch hissing noise which lasts for a few seconds. It's difficult to tell exactly where the sound is coming from, but it seems to be coming either from the fcu itself, or from the cables slightly higher up in the wall connected to it. I have unplugged all electrical appliances from the trailing socket so I'm pretty sure it isn't the sound of an appliance springing into life, and I can't think of any way in which the fcu could be being overloaded. I'm slightly worried about the noise - I can't smell any burning smell or anything like that, but I have a niggling doubt that the whole thing might suddenly burst into flames.
I wasn't aware of anything mechanical inside the fcu which could make a noise - I thought it was basically just a connector box.
Any ideas?
Thanks!
Any ideas?
Thanks!
