Installation via modern split circuit Consumer Unit.
1. Moffat (Electrolux) fan assisted Oven (Total Rating 2,075 W) its book says it needs a double pole 13A min, & min gap 3mm between the switch contacts.
I have an oldish "Metal Clad Double Pole Switch 13A with red neon light", how can I find if the gap is 3mm or not?
2. Moffat (Electrolux) Ceramic Hob 5.8KW, its book says needs D.Pole switch with 3mm gap, & the cable must be H0BB-F Tmax 90 deg.C or higher.
So what amperage must the switch be?.
It will came off a 32A CB & RCR of the consumer unit.
Thankx nick
Thankx nick
