Switches
1 May 2010
What would be the best switch to use for isolating socket used for washing machine under worktop, on ring circuit? Also same applies to switch to use on 2.5mm radial from 16amp on C/U to socket that will power 3kw oven and ignition for gas hob??
Be sure you provide correct fusing somewhere for each appliance.
The ignition will need 3 amp fuse.
