Hi. Looking at installing an extractor fan and spot lights for the new bathroom. Her indoors doesn't want the fan on with the lights and wants the spots to be dimmers.
Now, there are only switched lives at both the rose and the light switch and i can't access above the ceiling to try and find the jb with a permanent live.
I realise it's not safe to take the live direct for the shower circuit but is it ok to use the switched live from the lights and switch that? Not ideal i know but would just mean the fan would only run when lights are on and the switch is on.
Also if this is possible can you get switches which have 1 gang dim and 1 normal 1 way? Or should i get a seperate pull?
While i'm asking are 240v spots ok for bathroom as the low volt transformers are always going on the kitchen ones.
Cheers.
Cheers.
