In re-fitting my bathroom a sink is going to be fed from pipes that currently serve the bath, and a bath is going to be fed from pipes that currently serve the sink. No shower is involved.
The pipes to the current bath are 22mm for hot and 15mm passing to a short section of 22mm for cold.
The pipes to the current sink are 15mm for both hot and cold.
Am I right in thinking that so long as I adapt the pipes correctly (using flexible hose at the ends, too) so that I have a 15mm feed to the new sink taps and a 22mm feed to the new bath taps, it will all connect up alright?
Note that I may choose to have some basin taps on the bath, since there are no pre-drilled holes to work to anyway.
thanks,
thanks,
