Switching from mapp to propane
13 Aug 2021
Hi, I use the rothenberger superfire 2 with hose and mapp gas as that’s the gas the hose came with. Now it’s almost run out I have bought propane. If I am half way through soldering and the mapp runs out, can I switch straight to the propane as long as I empty the hose first? Just want to check there’s nothing else I need to do and if that’s safe? Any help is appreciated thanks! Btw I’m not a plumber
If you’ve bought non refillable propane, yes should be ok. If you’ve bought refillable lpg/propane, then you’ll need an adapter.
