My daughter has a problem with her Switchmaster room thermostat which clearly needs to be replaced. Drayton appear not to supply a direct equivalent now? I am due to visit in 2 weeks time, and can fit a new thermostat then.
However, from photos sent by my daughter, the thermostat appears to be of the type where the thermostat body and backplate are separate, allowing simple replacement by her earlier than I can do it. The question is:
Does this thermostat have this quick change arrangement, and if so, are there any current thermostats which are likely to fit the Drayton backplate?
Allan
Allan
