Hello, I own a 1980 2.3 L petrol Bedford CF 280 ambulance converted to a camper-van that now has a 2.8L diesel engine from a Diahatsu 4 trak in it. Since the engine speed of the diesel engine is so much slower I need an axle ratio on the back axle to be much less than it is now ( 5.22 to 1).. I seem to think around 3.7 to 1 is about right.
Now the question :- Would I be OK with disc brakes on the back instead of the drums?
My question to myself is :- Since disks are considered to have greater braking efficiency and there are drums on the front, will this cause uneven front and rear braking ?
From what I understand, disc brakes although more efficient and usually have higher hydraulic pressure applied to them via the master cylinder. So does that mean since the pressure applied to the now rear discs from the lesser pressure drum brake master cylinder, that the rear braking won't be so extra harsh. Or am I just confusing myself ?
A further questions might be :-
Cheers , Paul
- Can you envisage a problem attaching the hand brake cable ?
- Because it was an ambulance the rear springs are super soft and maybe weaker now that they were 35 years ago. Could I put and extra spring leaf on top or under the present one ?
- Is the width of the donor rear axle critical ( the body is coach built and mounted on the Bedford chassis and it is quite wide . Such that the width could increase a couple of inches before the wheels start to protrude. I was thinking maybe some weird handling concerns. PS I would rarely be going above 60 mph.)
Cheers , Paul
