fitted a new synchron today and all was ok, ch wasnt comin on when i demanded hot water. around an hour after i went to put hot water on and the boiler will not fire up now. dont know if this is because of the work that was done or not or just bad timing as for a couple days now the boiler is firing up as normal then after 5 min will reignite itself and also try ignitin whilst the boiler is actually burnin! anyway the pump is running and continues to run without switchin off, the pump is new and was fitted around 2 month back
boiler is a glow worm ultimate 30ff
pump is a grundfos selector
hope this is enough info and thanks for ur help
