Having had a new bath installed, it unfortunately had a shallow p trap fitted. Flushing the toilet syphons water out of the trap, causing smells. Unfortunately not enough room to fit standard P trap or bottle A/S trap. I've fitted an in-line non return valve which has helped but not cured completely.
Various questions.
Is there an alternative to what I've already tried?
There is too much water in the cistern. Would reducing the amount help against syphoning.
I'm reluctand to cutting a hole in the floorbords under the new bath, as you can understand.
Is it ok to make up a trap using fittings, to get the maximum possible depth of seal.
Although the bath is mounted at the same height as previous one, which had a normal trap, it's obviously deeper thus reducing space. That bit got past me. Any help please.
Various questions.
