I have a worcester greenstar 18i system boiler which is attached to a honeywell programmable unit. The programmer has the ability to heat water and central heating at set times. Is it advisable to set the hot water to heat at a time when the heating is not on, or can they both be on at the same time? If they can be on a the same time does the heating or water take priority ie does it take longer to heat the water?
