Is it possible to use a system boiler in an open vented system?
The system is in Ukraine.
Currently there is a 25kW gas boiler (cirsa 1950) and unused solid fuel boiler on an open vented wystem.
It is large (4") single pipe system, with large cast rads (about 350 Lts total).
There is over 32' head of water and an expansion vessel at the top of the pipework.
The system was thermosyphoning but now pumped.
The boiler and wood burner air intake is from inside the house and exhaust via flue pipe in a chimney.
The DHWS is done by a stand alone electric water heater (a cylinder may be included in any new scheme).
I want to replace the boilers with something safer and more efficient.
What is to stop me from using a system boiler directly connected to the system? (Manufacturers warranties asside). The system pressure would be maintained at about 1 bar.
Or would the ststem boiler need to be in a seperate circuit and to be coupled by heat exchanger?
For what reasons are system boilers closed circuits? Is this because we live in only two stoey buildings?
If I am missing some basic understanding, or if the question just seems daft, please excuse me.
Any thoughts/ideas would be welcome.
Thank you,
Thank you,
