We are having a lot of problems with our CH system. Over the summer we had TRVs fitted (8mm pipes) and a full system flush. We have an Apollo Fanfare wall mounted gas boiler and a pumped system.
Since we had the TRVs fitted we have had two problems
1. air in the rads, every 1-2 hours we have to bleed the air out for around 1 minute - this only occurs in the first two radiators in the chain
2. Extreme noise in the pipes which we think is caused by the hammer effect when the boiler overheats and feeds water back into the header tank. We have watched the header tank and water flowing back into the tank (very hot and fast) occurs shortly after the noise in the pipes
Please can someone advise how we may fix either of the problems. We have already turned the pump down from 3 to 2 to 1 and the problem still occurs.
The TRVs were fitted by a professional but they haven't been particularly helpful in resolving the problems that have occurred since.
Any help or advice will be much appreciated.
