I have a condensing boiler with two zone valves fitted.
One for ground floor and the other one for upstairs.
When heat is called only on first floor, radiators work fine and zone valve does its job. Radiators downstairs are cold( which is how they should be)
When there is no call for heat upstairs but there is call for heat downstairs this is what happends:
Radiator downstairs are hot and working as they should, but the radiators upstairs are luke warm and warm, when they shouldn’t and this is on all the radiators upstairs.
I replaced the motor on the zone valve upstairs and the same issue occured.
I then replaced the whole zone valve and the problem is still present.
Any ideas what could be the problem? Wiring, plumbing, anything
Zone valves are Honeywell if this makes any difference.
Thank you
Thank you
