Hi All,
I am currently re-boarding my loft after lifting old chipboard to put down insulation.
I am using 22mm P5 T&G Caberfloor boards. 2400mm x 600mm.
The floor was previously strengthened and levelled by running 3x2 joists at right angles across the top of the existing 4x2 joists.
The room is 3.9 metres wide and I am laying the boards at right angles to the 3x2 joists
The centres of the of new 3x2 joists are slightly erratic and range between 400mm and 500mm. I think that some have not been laid dead straight and are slightly on the tilt, or the room is wonky or both.....its a Victorian semi.
Because of this I have a bit of a problem where at the start of the room I have been able to stagger the ends of the boards so that the board end joins have landed on a joist for maximum strength. However, I am now at a point where I cant get the boards to land on a joist at their end unless I have them all landing on the middle joist. So I would effectively have 2 boards spanning the room (cut at either end of the room) with the join landing on a joist but the boards would no longer be staggered.
So my questions are:
1. Do the boards really need to be staggered?
2. If so, why?
3. Do the end of board T&G joints HAVE to end on a joist? Or can some be left with no support?
4. Am I better to stagger the boards and have some ends with no support underneath or (as described above) not have staggered boards but have all joins supported with a joist underneath.
As a bit or extra information: I am using "Floor tite" screws and glueing the T&G with D4 adhesive.
Any answers gratefully received as I am now in a state of "DIY FREEZE"!
2. If so, why?
