T Moulding
24 Jun 2007
I have just had my dining room floored with laminated flooring and the front room with real wood. However there is a ditch seperating the two rooms (I have two sliding double doors between both rooms).
There used to be a brass tack that divided it which was nailed down but now there is a ditch of about 1/4 inch deep, with the living room higher. As much as I would love to fill the ditch with water and play castles I was told by the builder that I needed a T-Moulding, what is it and where can I get one?
Dean
Hi Dean
A T-moulding is also called a Twin threshold. It's a threshold made in the form of a.... T
The depth you need is not standard, best to go to your local joinery and let them make it bespoke.
