T off 3/4inch pipe using 22mm to 15mm
5 Jul 2005
Surrey
I need to T off the main central heating pipes to add another radiator in a utility room.
I cant use compression fittings since the main pipes are touching the underside of the floorboars.
I suspect the pipes are 3/4 inch.
Can I buy a 22mm/15mm/22mm solder T pieces and solder it to the existing pipework? I know with compression you can buy the imperial olives.
I would prefer to use the compression fittings but the pipes are too near the floor boards.
Thanks :LOL:
not if the existing pipe is 3/4"" it will be tooo big
you can get imp to metric adapters tho
here yp1im slip ;)
I cant use compression fittings since the main pipes are touching the underside of the floorboars....chop a bit out of the underside of board :idea:
Can I buy a 22mm/15mm/22mm solder T pieces and solder it to the existing pipework? yes but you need 2x 3/4 to 22 adapter couplings
Thanks :LOL:
.You`re welcome :LOL:
Thanks for that
Can I cut 3/4inch pipes with a 22mm round pip cutter (forget the make). The type you can spin with one hand?
Or you could use compression fittings and just chisel out a little of the underside of the floorboard. Although you'd still need to adapt to 3/4" imperial using converting olives.
