T4 to LED
6 Dec 2007
Dundee
I have T4 lights under my cabinets. The fixing brackets have broken and getting replacements is nigh on impossible - unless I want to sell a kidney.
So the question is - is there such thing as an LED fitting that would use the T4 plugs - if that makes sense? Having just decorated, the last thing I want to do is have to replace wiring.
If you mean to fit between the two endcaps then its unlikely. T4 lamps use a lot of electronics to control them and i dont recall any Led lamp thats made to work with it.
However if your fittings have a mains inlet plug you may be lucky and get a complete led unit that accepts the sames mains plug.
Unfortunately these mains plugs vary make to make
