Brand new installation (December 08 )
Century lighting T5 fittings over a shop floor. Every week of so, another fitting stops working. Fittings have a single HF ballast and use four no. 14W tubes.
It seemed to be a particular area of lights that were failing - in the open area at the front of the store, no fittings failed, but down the aisles, 17 had stopped working by today.
Man came today to try and find the problem with them.
He started by simply unplugging them from the klik boxes above the ceiling and plugging back in. Some of them would then light briefly for about 5 seconds then go out again.
Most of the fittings came on by changing the tubes - some of the tubes that were in (and wouldnt light) were badly blackened on their ends. He tried some spent tubes (that looked ok) in brand new fittings but even then wouldnt light. Two fittings had to be swapped for new because even the new tubes wouldn't light.
He told me the lampholders were of very poor quality (bear in mind these fittings cost £100+ each, standard ones are about £35). The lamps had to be just so to be able to light. He re-lamped all 17 faulty fittings and said the spent tubes had been sent off for testing - it could have been a faulty batch of tubes (hence part of the store was still well lit - the original sparks worked from the back to the front of the store when lamping).
For now all the fittings are now working after relamping.
What do the resident sparks think?
Tube, caps or ballast?
Anyone used these fittings?
http://www.centurylighting.co.uk/products/commercial/president
