Hi. I've just removed a pir as it was in the way of my cable run and was hoping I could just put the alarm code in to reset the system but the alarm panel is saying restore required. I've refitted the pir.. How do you restore the system? Thanks in advance ...
Guessing its being set by prox tags its on police responce and is set to engineer reset on tamper, which you would have caused by removing the lid off the pir.
