- Joined
- 8 Sep 2004
- Messages
- 111
- Reaction score
- 0
- Country
Following a leak under the kitchen sink I have removed a rubbishy looking flexible hose and replaced it with copper connections.
Despite repeated attempts I have not been able to stop the leak. I think the problem is that the tails of the monoblock are tapered from 10-12-15mm. I thought that each separate section was of a uniform cross section for its length, about 5cms each. Now I am not so sure, as having removed the bottom 2cms of the 15mm section none of the service valves can be made watertight. This seems to be confirmed by using a spare (loathsome) pushfit connection which still leaks. Are these monoblock tails usually a problem or am I a complete halfwit?
