Taking a sink waste up to 40mm
6 Sep 2008
Madrab foretold this, and possibly its a regular noob mistake..
So I've picked up a 40mm hepvo and knuckle adaptor to make up a low profile sink waste. I'd already stuck a tape on the sink plug threads and measured 40mm. Great, that should be a fit then...
Having since educated myself that a 40mm o/d threaded waste is actually a 32, I'm looking for options:
I could return the 40mm hepvo and 40mm knuckle for a 32 of each, connect the sink to the knuckle to the hepvo, then work out a way to get the 32mm hepvo up to 40mm for the waste pipe after the hepvo
I could see if there is something that would allow me to keep the 40mm kit and increase the sink waste diameter to 40mm
Of the two I prefer the latter because a 32mm hepvo knuckle is 6 quid whereas a 40mm one is 60p, and ive a fair few to install so that would soon add up... But does such a thing exist?
I could return the hepvo and knuckle for a 32, then adapt the 40mm waste to 32 after the hepvo
I could see if there is something to keep the 40mm gear and up the sink waste diameter to 40mm
If I've read your post right then this should sort you. 32mm off sink waste to 40mm, your knuckle adaptor then your HepVo
http://www.plumbase.co.uk/polypipe-waste-to-trap-10000305-2204390
Jon
