I could use some advice and experience regarding supplying power to an Ext socket and power for a pond pump.
I have a switch fuse spur (fed w 2.5 t&e either on DS ring or on own cct undecided) to supply power to an outside cupboard fitted directly to the back of the house.
I've managed to get out of the back box straight through the wall in white plastic conduit. And will run the conduit through the fittings and out the cupboard along a wall to the pond.
I am thinking to use a ip54 20A 2G switch and a ip54 socket inside the cupbboard. And want to wire the pump (200w) and socket off the 2G switch. The socket will normally supply a pond air pump (200w) but would also likely be used for a lawnmower.
I was thinking to run perhaps 1.5mm arctic (?) in the conduit to the pond and use a waterproof connector to connect the cables that would be out of the pond but still in a 'damp/wet' but inaccessable location.
I could use an adaptable box to connect the cables but I can't find a way of getting a waterproof connection from plastic 20mm conduit (heavy guage). (Unless it is already IP rated enough if glued and with a lid gasket?)
Do I need a FCU between the 2G switch and the pond pump or would the RCD or RCBO trip before a 3A fuse would blow if there were a problem with the pump or cable?
Is it necessary to put a switched FCU inside the cupboard for isolatation?
If anyone has any suggestions or there are problems with what I'm thinking please let me know.
Thanks.
Thanks.
