Sorry in advance for the long post. I need some advice with a basement room. Any help is much appreciated.
I have a 3 storey building split into a house & a flat. The house is the top 2 stories, above ground. The bottom story is just one room under half of the ground floor of the house. This one room, along with a 2 story extension makes up the flat, with separate access.
This room, which is the kitchen of the flat has 2 and a half walls which are underground (cellar) walls. The "half", has a sloping path / steps running up the outside of the wall, ranging from about 2 foot to five foot up the outside of the wall. Of the other 2 underground walls, one has been rendered with some kind of cement and plaster, and seems dry. This wall is more under the house (perpendicular to the front) than the other underground wall, which is directly under the front of the house, we've hacked the old plaster off this front wall, to reveal the stone & damp mortar.
We've laid a new floor, with DPM, but left a trench filled with chippings along the front of this wall, and the half cellar wall, we also left a channel full of chippings under the floor, where there was originally an open channel running, covered with flagstones. We have built new stud partition along the full damp wall, and also along the 'half' cellar wall, as this is damp along it's lower half as well. We intended leaving the damp walls unrendered, so that they can breathe, and put vents in the stud partition to alow air to circulate, both around the walls, and under the timber floor of the room above. There are no air bricks at all, but an old chimney which has been tiled over, but is open to the attic of the house above. This will remain open, behind the stud partition
We've not boarded the stud walls or ceiling yet, as I'm not really convinced that our approach is correct. I'm wondering if we should really tank the walls to try & stop any moisture coming through at all, or allow it through in the hope that it will dry out in time. I'm thinking that maybe allowing it to breathe will create more moisture in the air, and make it harder to keep humidity down in the room / cavity / ceiling void.
The ground above & outside the damp wall is covered with flagstones. We've pointed the joints in an attempt to minimise water going into the soil, but I guess this will take a long time to have any effect, if indeed it helps at all. We're also installing an extractor hood in the kitchen to reduce moisture from cooking.
