I am getting a ensuite shower installed and just preparing the area now. I intend to use the dunlop shower waterproofing kit. A plumber will be installing the shower tray onto floorboards as part of his first fix and then returning to install the shower after i have tiled. i have never tanked before but have been reading around it this morning. I know the tape included in the kit is for internal wall corners/joins. Do I need tape up the joins on floor to wall before the tray is laid (the plumber said he will be using tape with the tray but i assume he means were the tray meets the wall. Do i also need to tank the wall to the floor before he installs the tray or is it ok to let him fit the tray and then tank from the tray upwards
Just not sure if the kit is for use after the tray is installed or before doing from the floorboards up. Any advice is most welcome
