this is the rough plan of a new bathroom I am fitting. As you can see two walls are external and will be sand/cemented then plastered. The two internal walls were going to be stud walls with plasterboard.
What I'd like to know is what product to use on each wall. The large rectangle is he shower enclusure. Instead of using plasterboard on that stud wall shall I use aquapanel? Or shall I use plasterboard and then a tanking product? The same goes for the external wall that will have one side of the shower enclosure on it. This will be plastered, shall I then batten and aquapanel it, or tank the plaster.
I presume the other parts of walls are fine as they are as they won't be getting wet.
I am hoping to tile natural slate onto whatever product I should use within the shower enclusure.
thanks
pic:
thanks
pic:
