I'm new to the forum and here because I indeed had a shower tiled by an obvious cowboy 4 years ago.
The wet room was obviously not tanked and subsequently the tiles have fallen off and the plaster behind was wet. The plasterboard is not damaged but the tiles have pulled off the skim.
I have done a little investigating into tanking but have some questions I would like to pose you guys here:
1, Is tanking a DIY job? I am fairly competant and have tiled before.
2, I have noticed that tanking kits generally come with a sealer for plaster, is this the best or should I PVA the plaster prior to this sealer?
3, BAL seem to state that tanking can be put ontop of tiles. Tiles have only come off one wall. Would it be advisable to remove all remaining tiles on shower walls or will tanking prevent moisture causing others to fall?
4, I have seen on this site that EPOXY grout is the only true waterproof grouting. Is normal waterproof grout enough if tanking has been done?
Sorry for such a long winded enquiry but I am very annoyed that the job wasn't done properly first at a cost of £500 for 1.5x1.5m power shower enclosure... plus tiles
