- Joined
- 11 Sep 2007
- Messages
- 827
- Reaction score
- 6
- Country
My oil tank has an Atkinson Tankmaster sight gauge assembly, like this:
https://www.fueldump.co.uk/products/Atkinson-Tankmaster-Valve-%2b-Sight-Gauge.html
Normally it's necessary to pull the 'pull to read' plunger to get a current oil reading on the sight gauge (the green bead will then drop down a little), however recently I've noticed that the level on the gauge (green bead) is going down (at the normal rate!) even though I've not pulled the 'pull to read' plunger, therefore it's acting as if the pull to read plunger has already been pulled out, even though it's pushed in.
I should emphasise that there is no oil leak whatever, the oil in the tank is going down as normal in accordance with how much I use the boiler. There's no oil or smell of it around the sight gauge assembly, or anywhere else for that matter.
I guess that a seal on the pull to read valve is perhaps not sealing correctly?
Along the same lines, I've also recently noticed that when I do pull the pull to read plunger there is some oil on the stem (in other words the part of the stem that is only exposed when the valve is pulled out). I've not noticed that until recently. Again, I'll stress that the oil is only on the stem.
The valve is also pretty stiff, not just to pull out but to push back in. It was last replaced about five years ago I think.
I see that it's possible to buy just a new pull to read valve:
https://www.fueldump.co.uk/products/Tankmaster-Pull-to-Read-Valve.html
Perhaps if I just replaced that it would resolve both of the aforementioned issues (oil level and oil on the valve stem)?
Looks like I just need to turn off the oil at the main wheel valve, unscrew the old pull to read valve and install the new one, is that correct?
Also, if I was to leave things as they are is there any danger of an oil leak developing bearing in mind the issues above? Or is that valve, etc all self contained and the 'worse case scenario' is that the gauge level drops automatically?
