Hi, Obviously I'm new to this forum but was wondering if you could help me.
The picture shows the external water mains (blue pipe) coming into my house in my kitchen under the sink. The old cut off tap (sideways) and the water meter with new cut off tap (to the left).
The old cut off tap is leaking whether it's on or off. You can see water coming out in the picture.
When the water meter was fitted is leaked a little bit for a couple of days but then was fine.
A couple of days ago, I turned off the water using the old tap (which was dumb) due to an unrelated leak with the cold water tank in the loft.
Since then the tap has been leaking.
Any suggestions on a fix? It doesn't matter if the tap is locked open due to the second cut off tap.
Currently I've got towels and bits of plastic wrapped round it which has slowed the leak, but not stopped it.
Help please!
Help please!
