I have bought a monobloc mixer kitchen tap, (Franke Eiger brand) and have tried to fit it myself. However, there are two 230mm straight copper connectors on the tap which are slightly smaller than those on the previous model. So there is gap between the pipe fittings.
It strikes me that fitting would be much easier if the Franke tap came with 300mm flexible connectors. I have seen some in B&Q/ Wickes etc for 10mm x 15mm and 12mm x 15mm, for a price that is pretty cheap in comparison to the tap!
So my questions are:
1) Would it be a problem if I replace Franke's fixed copper connectors with a generic flexible connector?
2) If no problem, what size I would need - is the measurement for the inside of the hole or from screw edge to screw edge?)
3) And, what is the advantage of a straight copper pipe, if any?
Huge thanks in advance for helpful replies!
