Hi All,
I wonder if someone could help. I've just fitted a replacement monobloc mixer tap, with braided 1/2" flexible hoses. The new hoses provided with the tap contsantly leak when attached to the existing 15mm isolator valve.
I would of re-used the existing hoses as they never leaked before, unfortunately one has sheared off on the thread, so I have re-used one, but can't get the other to seal.
The old connectors appear to have a larger nut, but other than that appear identical ! They also have pre-fitted washers, is it just a case of the rubber washer not seating properly, or am I doing something wrong ?
I've tried adding another washer in to the new connector, but it still leaks.
Cheers,
Cheers,
