I am planning to fit new bath and sink but have no tap connectors fitted. Am i right in thinking that once i have these fotted to supply pipes to taps I no longer have to shut off water supply at mains when working on fitting of new taps.
You can get flexible tap connectors with a built-in isolation valve at the end that fits to the copper pipe. They only cost a couple of quid more, no more expensive than buying a separate connector plus a valve.
