Hi folks,
easy one for you plumbers...
when I turn my hot tap (to turn it on) not much happens for a few turns then it 'catches' and suddenly turns on. Turns off as normal.
It's a kitchen mixer, hot & cold tap at each side. I've taken the plastic head off the tap but the only thing to adjust is one big nut that holds the whole tap on. My guess is it's old so i should remove this and just get a new tap, or is there anything I can tighten up to fix it?
Reason I ask is I need to drain the whole tank (no shut off valve after the tank...) before removing the tap obviously and don't want to waste my time if I'm gonna need a new tap..
Cheers
Andy
Cheers
Andy
