tap fittings
5 Jan 2011
Derbyshire
hi all. have just fitted a new bath and existing hot pipe is 22mm. cold is 15mm. my new taps both have 1/2bsp threads. had no problem getting a 15mmto 1/2 bsp flexi hose with valve for the cold feed but cant get 22mm to 1/2 bsp flexi for hot side.is one available because dont fancy soldering copper pipe. :cry:
Why not fit a 22mm x 15mm compression reducing coupler then fit a 15mm x 1/2" flexi.
My advice would be to buy bath taps for your bath because bath taps are 3/4" BSP thread and you'll have no trouble getting the right connectors.
1/2" bath taps?!?!?!?! :rolleyes:
The taps are bath taps and book says they measure 3/4 diameter,drilled 3/4 holes in bath 2 take taps .bought 22mm 3/4 flexi hose but tap connector was far 2 big. Am I missing something here.? 1/2bsp flexi fits onto taps but as I said I can't get 1/2bsp to 22mm. Any help would b appreciated as I am a lecky and not a plumber.
:oops:
Missing something? I think you are missing the few quid difference between the price of the 1/2" basin taps you were supplied and the 3/4" bath taps you paid for.
In 40 years of selling taps I have never seen a pair of 1/2" bath taps or a 1/2" bath filler or bath/shower mixer.
What make and model, and where were they purchased from?
thanks for all your help. Been in touch with the bathstore where i bought them from and it seems that old stock of the taps i bought have 1/2 bsp fitting and new stock have 3/4 bsp fittings. It seems i had old stock taps with a new manual. Should have got a conversion fitting for taps taking them from 1/2 iich to 3/4 inch. They are sending them out straight away. On the bright side they know me by name at screwfix ive been back and forward that many times. Thanks to all and a merry xmas :p :D :cool: :confused:
Bovine excrement! They're probably sending you a couple of 3/4 x 1/2" brass bushes.
Never have been, never will be 1/2" bath taps with converrters to 3/4".
Bath taps are 3/4", period.
just to let charnwood know they are barcelona bath shower mixer model from bathstore and cost me a fortune and yes they are sending brass bushes to take from 1/2 bsp to 3/4 bsp. cheers
A stunning and iconic design, makes any bathroom stand out
Stunning! Well, I was certainly stunned when I saw them. ;)
haha you were conned basin taps = 1/2", bath taps = 3/4", they have never made 1/2" bath taps, lets hope the flow rate is more than a drip
:oops:
A 3/4" tap tail will never fit through a 3/4" hole. Pipe fitting thread sizes refer to the bore of the pipe that's threaded, not the size of the thread itself.
Allowing for the wall thickness of the pipe, a 1/2" thread is about 3/4" diameter, and a 3/4" thread is about 1" diameter
id trust the opinion of charnwood over anyone and everyone together at bathstore, any day of the week
