Kitchen lever handled mixer tap (IKea Loviken) - hot tap started dripping and got worse rapidly to steady stream ...so bad had to isolate it ...
It is a ceramic disc tap and less than 4 years old....phoned Ikea and they have (free of charge) sent me out a new cartridge ...which arrived today...
I have original instructions and someone on Ikea fans has also posted instructions...
Basically it seems like you unscrew the top cover, unscrew the screw into the spline and then the lever bit should just lift off (then there is another cover thing and then you remove the cartridge)....
Only I can't get the lever bit off - have even given it a gentle belt with the hammer and it is not moving ...had a look at the cold tap too and that seems the same...can't see any little fixing screws or anything....think it has seized to the spline
So is this common/likely?
And what is the best way of getting it off? WD40? Heat (might wreck chrome finish!) ? Crowbar?
(patience has gone - feel like taking a sledge hammer to the whole thing - but probably not the best way to go... )
