tap problems
29 Jul 2004
all my other taps work fine but one that trickles instead of flowing
has anyone got any input for me
A few month ago I changed the washers in my taps (with help from this forum on removing the tap head) I had similar problem I had fixed the drip but had reduced flow, it was caused by the washer not lifting up properly, take the tap head off & have a look at the washer I rubbed my washers with corse emery clothe. All ok now. Well they were when I left for work.
Faulty washer? Spindle worn or limescaled up :( :)
Tap may need reseating.If you are confident change the tap with another you know works ( I have some old ones I keep for this purpose to avoid unnecessary expense). If this tap works then you know your tap needs replacing or washer renewal
I posted a similar problem some days ago, on the advice given I removed the tap body and seperated the two halves. Discoverd quite a build up of limescale which was not allowing the 'piston' part to move freely in the body. Quick dose of limelite and a rub with some emery cloth on the inside and job done. Replaced the washer for good measure as well.
Watch out for the thread on the tap body, mine was as sharp as a razor and left a nasty cut all along my thumb :oops:
