We've got two mixer taps in our house, one in the en-suite and one in the kitchen.
Both are a bit rubbish, you can't do much mixing with them as cold water is mains pressure and hot is from the tank. You only seem to get hot when it's all the way across towards hot, any amount of cold gives cold water.
Also it's a bit of a trickle in the en-suite it's not really enough pressure.
I've been having a read on here and I think it's down to the wrong taps being fitted. I'm guessing they are mains pressure taps for combi boilers etc?
Is there any way to alter the taps to make them work better?
Is the pressure issue related?
I thought that hot water pressure was down to height difference between the cold water tank and the tap? We have another bathroom which has sperate hot and cold taps and that one gets much more hot water flow and is at the same height. The en-suite is further away though.
