I'm replacing a ceiling using 12.5mm tapered edge plasterboard.
Is it ok to put the screws into the tapered edge or should i fix it on the flat just before the taper starts?
Also, once i have joint taped, filled and sanded is it ok to paint straight onto the boards?
