taps
9 Apr 2007
Berkshire
I purchased some new taps for a sink/wash basin but they don’t fit.
I then discovered that the threaded part on the existing tap is 20mm but the new tap is 22mm. Have I purchased the wrong taps or is there something I need to do to convert the existing nut on the pipe to fit a 22mm thread on the tap?
Basin taps are 1/2" bsp bath taps are 3/4" bsp sounds like you have bath taps instead of basin , so looks as if you need to change them !
OK thanks :)
Looks like I need to go back to the shop to exchange them, but I have a nasty feeling they wont take back the ones I tried to fit as the (plastic) nut on the tap shows signs of being 'used'.
Anyway, I learn from experience.
Thanks for your help
