I've just bought a power compound mitre saw and the results I get from the 24 tooth TCT blade leave a lot to be desired.
The underside, back edge and the LHS of the cut all suffer from splintering (is it called ripout?)
Would I get a better result (less rip out) from a 32 or 40 tooth TCT blade?
I'm just playing with odd lengths of wood at the moment but will eventually be using the saw to cut laminate flooring.
