Tears in new roofing felt
29 Jun 2023
We are having our roof replaced and the roofers have now laid the new roofing felt on and battoned down and will start tiling next week. However, having looked at their work from the inside I can see 4 very small tears in the membrane. Looking outside it looks like they have used gripbond pro adhesive & sealant over the top of each tear to seal it and the sealant has cured and is like rubber. Would I be silly to ask them to replace the felt knowing that once the slate is on it shouldn't leak and that the sealant is probably enough to stop any water ingress if the slates did leak?
I have also placed some gorilla patch and seal tape to the inside of the felt under each tear.
At the very least get them to tape over
A simple patch is easy enough . It doesn't require replacement ..unless of course it's battered
Ask them to use a patch from under the lap above or below if the holes are lower on the run
