- Joined
- 17 May 2009
- Messages
- 2
- Reaction score
- 0
- Country
I have a shower system which requires a balanced water supply. I believe I have one since I have Megaflow installed and a plumber has confirmed that the system is balanced
The pressure of the water in the shower is very low and I need to boost it. Need to check the following:
1. Can I install a techflow pump to my system ie just before the pipes feed the shower mixer valve?
2. If I install a techflow pump which has a facility to boost the pressure of hot and cold water, will the pump ensure the water is balanced? I plan installing the pump on the hot and cold inlets to the mixer
Can someone help please?
Many thanks in advance
