Tecumseh refridgerator compressor start device availability
2 Nov 2009
Kent
Hi folks,
I have a Tecumseh compressor (Type THB 1330 MKS) on a Hotpoint larder fridge. The start device is totally burnt out. Fell apart in my hands. :cry: The compressor windings all test ok, approximately 78 Ohms between pins, Infinite resistance to earth. So the motor seems ok. I understand that a Danfoss start relay can't be used on these compressors. Any one know different?
Also, any idea where I can source a replacement start device? The case marking is 'BRPT2116' & 'SR273104'
All assistance truly appreciated. :D
If your compressor is of the three pin variety you should have 3 readings
Pin A to B = X ohms (Start to Common)
Pin B to C = Y ohms (Run to Common)
Pin A to C = X + Y ohms (Start and Run)
