Hi I have bought an under sink water filter and water to tee off the cold drinking supply so I have one feed into the cold unfiltered feed of the tap and another to supply the water filter. What product is suggested please
Are the pipes copper or plastic ?
If copper ,you can use soldered ,compression ,or push fit fittings.
If plastic pipes you obviously can't solder ,but either of the other types of fittings can be used , together with pipe stiffeners.
I thought I already did ? You want a Tee to fit into your mains cold supply pipe, take your pic from the 3 that I suggested.
A picture of the pipework under the sink might be worth showing us.
