Telecom Elite - change part arm text
12 Feb 2021
Hi all,
Is it possible to change the part arm text for part arm options 1, 2 and 3, or are they hard coded?
They are currently "Evening arm", "bedtime arm 1" and "bedtime arm 2".
I've a good search through, but this eludes me!
Thanks. I'd got that bit, but where is it set? I can't find it in the part arm settings, so I suspect it's hidden elsewhere...
Aha! Just found "part arm text" in the global options. That sounds hopeful...!
Thanks, I think I got to it just before you posted!
Is it possible to hide unused part-set configurations from the user? In this case, I have two ("evening", "bedtime") and would rather the other does not appear. I've named it "DO NOT USE!" for now, which I guess is functional, if not elegant ;)
No ...program them all the same if your worried about selecting the wrong one ...
