- Joined
- 13 Jan 2004
- Messages
- 1
- Reaction score
- 0
- Country
I have a Teledyne Laars Mini-Therm II, it's a hot water bioler for a house in Canada. The temperature sensor is continously tripping, I can't run my system for more that 5 minutes. I've had 3 "pros" ahem, come out and they just clean the thing, two have said they don't like this system. Is it possible to replace just the temperature sensor? Has anyone else had problems with this furnace unit? I've checked for back draft, the furnace has a build in flue damper, once the furnace turns on and the flame starts, there is defenitely air intake where the air intake and heat sensor are located, but right at the upper most part of the openning there does appear to be some very minor backdraft. This confuses me. Smoke from a burning piece of paper is clearly drawn in, but right at the very top, like only 1mm gap of air is where the smoke blows forward ever so slightly. I don't know if this represents a problem or not.
Any suggestions?
PS. House is cold
Any suggestions?
PS. House is cold
